I have a client who has a 220V-3phase 70KW electric oven from China that needs to get installed. The building has Y 208-120V system but the actual voltage is 214 Volts between the phases.
The building is vacant and no additional load are connected. i am thinking once the electrical system gets loaded the 214V will drop to more close to 208 or even less.
So, do you think i should install a boost transformer or not worry about it since there isn't much voltage difference?
Thanks for your input.
