A luminaire under a certain weight (recessed can) doesn't need suplimental support (jack chain) and that the MC cable its self is adequet. What article in the NEC am i thinking of???
(B) Suspended Ceilings. Framing members of suspended ceiling systems used to support luminaires shall be securelyfastened to each other and shall be securely attached to the building structure at appropriate intervals. Luminaires shall be securely fastened to the ceiling framing member by mechanical
means such as bolts, screws, or rivets. Listed clips identified for use with the type of ceiling framing member(s) and luminaire(s) shall also be permitted.
