UV damage and ladders
JJWalecka
New England
I have noticed that the sun can be brutal to ladders.
What steps do others take to protect ladders and get the most use out of an investment?
I was reading about periodically coat ladders with polyurethane, wax or acrylic paint, to combat the effects of sunlight on the ladder.
John120/240
Olathe, Kansas
I have no experience with polyutherane or wax, but I do know never ever paint a ladder. The
reasoning is that the paint will make a defect in the ladder harder to see. Painting your company
name or such in stencils on the ladder should not be a problem.
JJWalecka
New England
It was my assumption that painting was a no no also. I was surprised that Ehow suggested it.
Fulthrotl
~Autocorrect is My Worst Enema.~
painting a ladder violates OSHA, i believe.
Ehow violates common sense.
edit:
werner suggests painting. i was taught in my apprenticeship painting with anything
other than clear was verboten, violated OSHA regulations.
i still hold that Ehow violates common sense. i'm not moving off that position.
petersonra
Northern illinois
engineer
edit:
My understanding is the OSHA issue with ladders is painting over the warning labels and instructions. As long as you don't paint over the labels, it is not an OSHA issue. YMMV.
renosteinke
NE Arkansas
Fiberglass ladders actually have an outer layer of PVC, put there specificallyto protect the fiberglass from both mechanical and sun damage.
There's no rule against painting a ladder; lables that are missing, or illegible are a favorite 'violation' of the seminar-trained crowd. Note - again- that OSHA does not have jurisdiction over the self-employed.
I am personally convinced that this whole 'don't paint the ladder' cant is a rumor created by theives to make it easier for them to ply their trade.
Note also that there is no requirement that ladders be any particular color. Paint them pink, or camo, for all it matters.
JJWalecka
New England
Just received an email from customer support at Werner ladders. The following is a quote from the email.
"The Werner Co. does recommend that you refinish or recoat a fiberglass ladder.......First you will go over the surface of the ladder with a light abrasive, then wash the ladder. Then using one of the three acceptable coatings, you will cover the fiberglass. Anything with a colored pigment in it will add protection to from the UV rays, however it is not necessary. Either way, recoating the ladder will result in keeping the fiberglass particles from irritating your skin, and prolong the life of the ladder. Depending on where the ladder is stored, I do recommend doing this at least once, if not twice a year to maintain the ladder."
I couldn't attach the file. Google Werner fiberglass technical manual for more info. Check out page 5.
News to me.
copper chopper
wisconsin
I recently just took an osha-30 course and this is how osha stands on painting ladders- you cant paint labels but you can only paint 1 side of the ladders. so if there is a crack or some other flaw you can still see it from the inside part of the ladder.If you still dont get it I can try to scan the article out of my osha book.That leads me too another Question how many shops out there still use WOOD ladders.. we still have a few floating around I hate them luckily for me they are not allowed in hospitals as wood can have a lot of things living and hiding in it.
USMC1302
NW Indiana
I believe there was another thread on this a few years back? As far as wood ladders, there are some good ones out there if so inclined. I believe San Francisco Fire Dept has their own ladder shop, and they use them exclusively...
Hv&Lv
Engineer/Technician
News to me.
I have it in post #4
