What happens if you apply 240V to a 480V motor?
I have a coworker who is having trouble with a submersible pump. It is only pumping about half the volume-per-minute at half the head as it is supposed to be moving. The pump is wired at 240V 3-phase. I am wondering if the pump motor is actually tapped for 480V.
I know a 480V motor will spin if 240V is applied (after all, that is how reduced-voltage starters work, right?), but I don't know exactly what the failure mode is if the motor is wired at the wrong voltage (higher current? higher slip-rate? lower torque? or will it just burn up?)
Any insight would be appreciated!
(P.S. - my other thought is, maybe a phase is switched and the pump is running backwards)
