learning99
Greetings,
I'm trying to understand a machine's use of an autotransformer, and whether or not it "meets code". This industrial machine is powered by 480 delta 3phase (3 wire). The machine is designed with several motors running off 480, 3p, and a 3phase autotransformer. The autotransformer input is 480 and the output is tapped at 400V, 3phase. 400V single phase is used to power a cartridge heater (4KW). 230V single phase is derived from 400V and the autotransformer 0V reference (I guess the end of the autotransformer). 230V is used for printers, a PLC power supply etc. I'm new to autotransformers and this area of NEC..... Is it "ok" to have this ungrounded 230V? It is "ok" to have a heater load off the autotransformer? NEC refers to ground detectors being used in ungrounded systems.... How does that fit in? I should add this machine gets installed in MFG facilities where only 'qualified' technicians/electricians would work on it.
Thanks in advance for your help and patience.
Learning99
Learning99
