JDB3
 - San Antonio, Texas
:?   Square D Homeline 42 circuit panel.  2 AFCI tripped.  With one, I found the entry fixture would trip the AFCI.  Took the bulbs out, did not trip.  Took the fixture down & found continuity between neutral & ground.  Put up pig-tail socket and that circuit if fine!
2nd circuit. Lights, fans, & one receptacle. The 2 patio fans with light kits on dimmer & speed control work fine as does the duplex receptacle. Dinning fixture on 3-way switching causes the AFCI to trip. Take out bulbs, doesn't trip. Take fixture down and put up my trusty pigtail socket -works fine UNTIL I put light bulb in, then it trips. (so much for my trusty pigtail socket). Ring the wires to the fixture (12/3 w/g wired for future fan) all the wires ring clear. Fixture rings clear. Did not have much hair to start with, but have less now.
Any thoughts out there? Thanks in advance!!!!!!!!!!!
