Sierrasparky
- USA
- Electrician ,contractor
Does anyone know if you need a Contractors License in the state for which the work is in.
I assume that means if on federal property that you are also exempt from local AHJ permits and inspections? If not that contradicts the rules of the state AHJ we have here - you must have a State contractors license to file permits, and the contractor pulling the permit must be the one (or the one responsible for) the work.Been a while for me doing federal work, but it used to be that if it was work on federal property they did not care what your home license was as long as you had one from somewhere. If it is private property that is being leased to the feds, then you need the appropriate local license with the AHJ.
