hoyerr
 - Warrensburg Missouri
I need a code interpretation.  I have a questionable installation.  I have a fiberglass enclosure that contains a bus strip with 4 4/0 weld wire cables attached.  These are connected vertically.  They exit the box thru a bushing, also vertically.  There is a web type cable support attached approximatly 2 feet away.  My question is Should the bushing be replaced with a strain relief fitting where it exits the enclosure?"  I am looking at Art 312.5(C).  I am being told by my electrician that the use of the remote web strain relief is sufficient.  I think this is entirely 2 different issues.  One is the exit thru the enclosure and the other is the required support for a vertical cable.
