mstrlucky74
- NJ
Are surface mounted panelboards usually mounted on strut/kindorff? Thanks.
No, usually just mounted to wall.
We are talking about to a wall, correct?
Yes. So I guess a block wall you would use strut for sure.
Toggle bolts or tapcons work just fine to mount the panel to a block wall.
Unless there is reason to add strut behind the panel, it is unnecessary.
