AV ELECTRIC
hi guys
replaced a 100 main breaker on challenger combo meter and panel outdoor for a residence this breaker was burned up on b phase
it appears we are having the same problem with the new breaker loosing power on half the house if breaker is reset power comes back on. they did replace the condenser thinking that may have been the problem. this appears to be an arcing problem and not a short or overload because the breaker does not physically trip and no other breakers are tripping either but like i said if main is turned off and reset power comes back on
is it possible the problem is on poccos side we have called them out to check. the bus bar is fine a little darken on b phase where the old main breaker was attached but not damaged did not see anything on the line side of the breaker from the meter
any thoughts would be appreciated
