mstrlucky74
- NJ
If the above switch is a 2 pole switch doesn't it have to be feed from a 2P breaker? I ask because it is showing it being fed from a 1P 20A breaker. Although, I do see in the description below it says there is an option for 3HP @ 240V 1phase. Can these switched be fed single phase? This is were I need a little wiring/theory insight.
| SQUARE D | ||||
| Mfr Brand Name: | SQUARE D/TELEMECANIQUE | |||
| Catalog No.: | H221N |
| UPC: | 785901-47768 | |||
| GTIN: | 00785901477686 | |||
| TRA-SER PIK: | 598183 | |||
| Product Name: | SAFETY SWITCH | |||
| Description: | SWITCH FUSIBLE HD 240V 30 | |||
| Commodity: | 31310 - Fusible Heavy Duty Safety Switches | |||
| Long Description: | HEAVY DUTY SAFETY; 240 V AC VOLTAGE; 250 V DC VOLTAGE; 30 AMPERE; POWER RATING 1 1/2 HP AT 240 VAC 1 PHASE, 3 HP AT 240 VAC 3 PHASE (STANDARD); 3 HP AT 240 VAC 1 PHASE, 7 1/2 HP AT 240 VAC 3 PHASE (MAXIMUM); 5 HP AT 250 VDC; 2 POLE; 3 WIRE; CLASS R FUSE; FUSIBLE FUSE; SOLID NEUTRAL; NEMA 1; SIZE 7.55 INCH W X 4.88 INCH D X 14.6 INCH H; APPROVAL UL, CSA; SQUARE D[R] BRAND | |||
| Country Of Origin: | United States |
