PART OF 501.15 STATES "Conduit seals shall be installed within 450 mm (18 in.) from the enclosure. Only explosionproof unions, couplings, reducers, elbows, capped elbows, and conduit bodies similar to L, T, and Cross types that are not larger than the trade size of the conduit shall be permitted between the sealing fitting and the explosionproof enclosure". MY QUESTION IS WHEN TRADE SIZE IS USED IS IT A REFERENCE TO THE CONDUIT OR THE THREADED ENTRY ON THE ENCLOSURE? EXAMPLE BEING IN A CL1 DV1 LOC. EXPLOSIONPROOF PANELBOARD WITH A 3 IN THREADED ENTRY AND USING A 3 IN NIPPLE, 3 IN UNION, 3 IN TO 1 IN REDUCER TO BE ABLE TO INSTALL A 1 IN TMCX, OR SHOULD IT BE REDUCED FROM 3 IN TO 1 IN AT THE PANEL AND BE DONE WITH IT? MAYBE THERE IS A PART OF THIS CODE SECTION I AM NOT READING RIGHT ANY HELP WOULD BE GREAT
