What issues are created by pulling conductors in a raceway with a forklift or truck?
Is there a formula for the amount of lube that should be used?
well, you need to have a strategy that transfers the pulling force into the conduit, instead of the supports, panel, etc.
otherwise, you will likely pull it off the wall, etc.
forklifts work well. i used them before i bought a tugger.
smart money is to put a straight leg to the floor, use a sheave
mounted to the floor, and pull using the forks to lift,
with a cats paw around the fork.
take a bite, pull till you run out of up, lower and repeat.
driving anything, you run the risk of hurting someone, or having
the wire lurch, and skin it.....
let's look at the economics of this.
you are pulling three 500 mcm's and a ground 100'.
you skin one of the wires jerking with a truck.
you have to pull everything back out, and eat one wire.
500's in copper right now, are $9.75 a foot.
so, that cost you a grand. you can buy a decent tugger used
for less than that. you can buy one new from maxxis for a
couple thousand. their stuff works well.
you can rent one for $125 a day around here, including all
the accessories for barbie. ropes, sheaves, pulling wheels, etc.
as for lube? order simpull wire. don't lube it at all.
like the man up there said, megger when done.
