NOBODY claimed a free lunch, with ANY of the arguments.
I went back and re read the posts.  You are correct.  No one claimed a free lunch.  Just a different way to make electricity.
Why we may need such a thing or not was not part of the OPs discussion.
However, there just may be an application for this idea.
Take a look at the valve stems for any vehicle made after '08.  See the big, expensive, black box that goes on the inside of the rim?  That is a pressure sensor with a radio in it.  The radio sends signals to the instrument panel for tire pressure and most importantly, to activate the low pressure warning light.  These devices have to have a power source.  They are called dTPMS devices.
From Wiki:
			Most originally fitted dTPMS have the sensors mounted on the inside of  the rims and the batteries are not exchangeable. With a battery change  then meaning that the whole sensor will have to be replaced and the  exchange being possible only with the tires dismounted, the lifetime of  the battery becomes a crucial parameter. To save energy and prolong  battery life, many dTPMS sensors hence do not transmit information  during standstill at all or apply a complex and expensive two-way  communication which enables an active wake-up of the sensor by the  vehicle.
So, you can see that battery life is a major design concern.  No battery lasts forever, and the sensors are $70 each, not including installation.
Using electricity generated from the tires would mean that the batteries could be eliminated.  A capacitor could store enough energy for one or two read outs while the vehicle is stopped.  Once the vehicle starts to move, the tires could re-charge the caps and supply energy for monitoring while in motion.
Since the tires are not moving relative to the sensors, this makes them a great source of energy that would not require any form of sliding contact, brushes, etc. to get the energy to the sensors.
