DTan
- Northern Minnesota
Has anyone every used anything like this to control receptacles for engine block heaters?
http://www.iplc.com/files/IPLC2006a.pdf
Who uses engine heaters other than for diesel engines? (the picture in the brochure showed several vehicles that likely did not have diesel engines)
Up here, we get plenty of days where the highs don't get above 0 Fahrenheit. Lows can get to -40. If you want a gas car to start in those conditions, it needs to be plugged in for at least a few hours. I'm looking at something like this for both semis that come and go at all times of day and the employee parking lot where we have enough different start and end times in the plant where a simple timer probably isn't going to work so well.
I don't think starting is the only issue. Having a block heater lets you get heat to the interior a lot quicker than without the block heater....I also don't think starting a fuel injected engine when cold - even -40oF is as much a problem as it was for carburated engines. Getting right fuel mixture was a problem and was easy to flood them, the electronic fuel controls do a much better job of getting the right amount of fuel in there at the right time. Diesels are better than they used to be but still can use an engine heater.
Cold oil is also a problem. It puts a lot of strain on the starting system, as well as not doing its job of being a lubricant.
Last page of the brochure in post 1 says it is copyrighted 2006, and is a Canada company. They may make them with WP in use covers, and I have no idea if Canada code requires the in use covers?Is it ul listed ? Couldn't see how it would be without "inuse" covers.
