No, you really DON'T want to use a modular plug. It takes a great effort to reliably install them and your chances of screwing at least some of them up is nearly 100%. When that happens you won't know which end has the problem. If you must test, punch the ends down on jack inserts. At least those are semi-reuseable and you can see what you did. Better yet wait for the geek to install the patch panel then blame the problems on him. And he shouldn't be using plugs either.
-Hal
yup to all of that.
when i put in a data cable, i punch down to leviton cat 6 modular blocks on both ends, and certify the cable.
it's included in the price of the cable.
if the cable can't be put where it's final happy home is, and is coiled above the t bar, it still has a cable label on
it, and a jack, and is certified.
the short version is, "i'm done, pay me."
if you want me to do additional work on that cable, it's a relocation and recertification, at half the cost of a new cable.
simple.flat.rate.pricing.
and landing it into an 8 port rj-45 plug is not approved under the 802 standards, and it's like packing a marshmallow into a
piggy bank. try making a patch cord that certifies, and see how long it takes.
a leviton 6E+ jack is about $6.50, and i NEVER have problems with them. ever. i won't use anything else.
