JJWalecka
 - New England
Anyone used the carbide tip hole cutters?
Worth the money?
How long do they last?
			Worth the money?
I bought one of these several years ago. Kept a log on the 1-1/8" cutter and drilled over 300 holes in standard galvanized panel tubs with no discernible dulling.
http://www.ohiopowertool.com/p-311-hougen-electricians-fabricators-kit-14005.aspx
I don't like that style. I've used both the Ideal and Greenlee quick change hole cutters, they make holes just like a hole saw does. Once you get the pilot through, the hole cutter seems to walk around on the material just a teensie bit making it take longer than the Greenlee Ultra Cutters I've been using for years now. Ultra Cutters don't have the super deep throat like the one you have pictured so sometimes you have to hit a hole from both sides, but they cut faster IMO. With a little cutting oil and slow speed with lots of pressure they blow right through stainless too.
http://www.amazon.com/Greenlee-930-...225137&sr=8-11&keywords=greenlee+hole+cutters
I probably get a year plus out of the cutters since I don't run them fast, 1st gear on my Dewalt.
My two cents, I agree with you and Cow. The Greenlee link that he offers is the same patent as this one, so shop for the best features and price. Greenlee just bough tthe right to distribute the Hougen patent. Hougen is a big name in drills. I like them far better than the carbide tiped ones, because they are less expensive, and I think they cut better when they are fresh. If you look at the cost of one of these for 1/2 and 3/4, compared to a unibit, you should conclude that they are a far greater value. I stopped carrying a unibit that went any larger than 1/2" (actual, not pipe size) when I discovered them.
A little trick... If you need to drill out a hole larger, get a blank 4" cover, zip screw it under the hole, and use it for you pilot bit guide, you will be through the metal in seconds.
I have a few of those Ultra cutters cow gave a link for. I too like them better than the carbide tipped cutters. They cut just as good, cost less, and is like a hole saw - probably helps keep cost down- the arbor is separate component from the cutter, so when you need to replace you only replace cutter and not entire assembly. I need to get a few more larger cutters - then I may not use KO punches much at all anymore.
Best thing since sliced bread. :happyyes:
One detail to mind is: what are you drilling?
Believe it or not, there are different grades of carbide - a saw might be designed to cut masonry, and still have big teeth. READ the fine print. You can 'get away with' using a carbide saw on the wrong material, at the cost of greatly reducing its' life.
Along with that, keep in mind that a slow spin with a hard, steady push is the way to drill. Sometimes I almost want to curse the folks who made hole saws to fit in standard drills, as there is such a temptation to squeeze the trigger all the way. That's what's nice about the 'hole hogs;' they spin a lot slower than the usual drill.
So I am supposed to get the hole hawg out to drill an entry for 1/2" raceways into a box? I'm pretty good at keeping the speed of my cordless drill at an acceptable speed for this task.One detail to mind is: what are you drilling?
I believe a very slow speed to be important as higher speed cause heating which hardens the steel being drilled being counter productive.
I haven't had to drill through stainless steel with a jobbers bit in quite a while but I know that the bit can be destroyed unless you have the patience to drill at a very, very slow RPM. With a higher RPM the heat will cause the SS just to get harder making it an impossibility to drill through.
Have any of you heard of that?
	The greenlee kit has 1/2" to 1.5" that fit onto a single arbor.
Best tool to come along in decades. They last a loong damn time unless you do something stupid with them.
And, only just over $100. They used to be more expensive. I've been using them for many years. No more scrounging for hole saw parts. Everything is in one small kit in a decent box.
Buy one today.....seriously.
I like these
I like the cleaner look of the punch. Other than punch sets, I have the old-style hole saws so maybe I have missed out by not getter some newer saw technology.why not drill a larger hole in first place?
