Brandon Loyd
Is it legal to take the tie handle off of a 3 pole 20 amp bolt on breaker, and turn it into 3 single pole breakers?
Handle ties do not make it a common trip. The common trip is internal to the breaker. It will still be a common trip breaker after you remove the tie.The handle tie was factory installed. My assumption would be that the handle tie is the only thing making it a common trip, as you can independently turn each pole on and off. But I don't know if all 3 will trip together with the hangle is removed, and under "trip" situation.
