Initial thought... is the cable inside or outside of trough (i.e. wireway)?CAN YOU USE A WIRING TROUGH AS A CABLE SUPPORT BOX.2008 NEC
lets say 3inch conduit run as a riser with lets say 4 500mcm cable support every 50ft
can a wireway {trough} be used for the cable support bushing and cable support wedge
lets not forget the ends of a wireway is only supported by screw . not a welded box like most pull boxes.
