dielectric
 - virginia
have a strange problem to try and fix. would appreciate any ones input and or advice. went to apartment unit for a service call, the tennant smelt burning and the maintenance guy found 240 volts at the receptacles and heard the fluorescent light buzzing. turned off the light and tried a few different things ( changed  main breaker, swopped meter at meter base ) nothing fixed the problem.
I opened panel and removed all the breakers and turned the main breaker back on. everything read correctly from neutral to each leg, from leg to leg, from leg to ground. ( 4 wire panel) started installing each individual branch circuit and some circuits were fine and some caused the voltage on one leg to drop to .4 volts and 240 volts on the other leg. at some point i had the receptacles in the living room working and went back to check them a half later later and they were back up to 240 v.
going back tomorrow to do a more in depth search and analysis but was wondering if anyone has encountered such a scenario before.
