Not sure if this is the best forum for this, but it seems to attract panel shop questions...
Trying to come up with a way to power up 3 phase control panels on the benchtop for testing before they leave the shop. We only have 1ph 120/240 available. Don't need much power, just enough to fire up the control circuits, etc.
Right now we just power up the two legs that supply the control circuit, however this doesn't allow complete testing of phase rotation, instrumentation, etc.
A rotary phase converter wold be okay, but they are big and expensive. I only figure I need around 250VA. I thought about picking up a cheap 1ph in --> 3ph out VFD (less than $100) and set the output to 60hz, but I assume the output waveform would be too nasty. Perhaps with the right capacitors the output could be cleaned up enough.
I see some swanky 3ph lab power supplies but they are thousands.
Any ideas? How do you guys deal with bench testing?
Thanks.
Thanks.
