timm333
- Minneapolis, MN
- Electrical Design Engineer
What should be the size of grounded (neutral) conductor in a 120/240V 3-wire single phase system as per NEC?
The 3-wire single phase system has one grounded (neutral) conductor and two ungrounded conductors. The one grounded (neutral) conductor carries current from both ungrounded conductors. So apparently the size of grounded (neutral) conductor should be twice as big as each ungrounded conductor; is it correct?
