Duncan8943
 - Lexington
I've got one generator and two automatic transfer switches installed in a duplex.  A 240 VAC signal is supplied to the generator which maintains the battery, but more importantly turns the generator on when the 240 VAC drops out.  Each duplex is fed from the utility which goes through each utility meter and service disconnect on the exterior of the building.  Where would you tie the 240VAC signal in and why?  If you tie it in downstream of the disconnect for either side, then someone could easily think that they killed the power to the duplex and within a couple of minutes there would be power on the circuits.
