Drummond
- fowlerville michigan usa
I am looking at wiring some underfloor heat ribbon which are 20" wide and are placed side by side with the conductor
attachment points on each side of the ribbon. So basically you bring your 120V or 240V hit the 1st ribbon and then
jumper to the next. What kind of wire can be used from the tstat to the heat. 300.3 says I can't use single
conductors and Type FCC cable(sec.324) is not permitted in residential. What other options are there??
