Like Don said, you don't have a problem - unless a low impedance tester shows the same voltage (it probably won't). This isn't STRAY voltage, but PHANTOM voltage introduced in a floating (unconnected) wire by capacitive coupling. Capacitive coupling is how tic testers work. Your body mass is capacitive coupled with ground, so voltage in a wire will complete the "circuit" and the tester will light up. That doesn't mean there's any real voltage moving through you, just the signs of that voltage. A high impedance multimeter (~10 megaohms) is sensitive to this induced voltage and will give you a reading of the capacitive coupling but in reality you have no useful voltage available. You will see this phantom voltage at almost all three way switches and some switch loops, especially with burned out lamps or non incandescent lights where your switch return doesn't have a solid connection to neutral through the lamp.
