DesignerMan
- Lititz, Pennsylvania
Got a call from a customer who says he had some receptacles not working. When I got there he told me it was (3) bathroom receptacles and the outside receptacle. I checked them each with my DMM and found the following readings:
hot to neutral = 96V
neutral to groung = 24V
hot to groung = 120V
Checked the breaker panel and found everything to be ok- breaker feeding this circuit read 120V.
Then found GFCI receptacle that feeds these receptacles next to panel.
Everything reads fine at this receptacle and it was wired correctly (line and load).
Customer said problem began when he had a remodeling done and the inspector required this GFCI be installed. Said the receptacles did work at one time but soon after stopped.
Note: House was built in 1990's with standard Romex wiring.
Any help would be appreciated- I'm stumped.
Thanks!
Thanks!
