JJWalecka
- New England
Has anyone used the Caddy Rod Lock beam clamp?
Haven't seen those. Is that a set screw, tightens to hold rod in place? Does this damage threads or could the rod be moved later for some adjustment? Looks handy if it works well; fewer nuts & washers needed.
Very common use in making trapeaze supports for cable tray or conduit support.
Unistrut also has a good line of beam clamps with j-hook lock down.
dick
