What does it mean when the display in generator says low voltage, Is this the battery
It all depends upon the circle of those you are with. I always understood that HV was 35KV and above, MV from 35kv to 1000v and below 1000v to be LV.
Voltages 48v and below as limited energy.
But that's the industry that I'm from.
Some consider 480v as HV based when 120 and 240v being normal and 48 and below and LV.
As such you are correct when you ask what does Low Voltage mean as LV could mean a different thing to a number of people.
Somehow I don't think that's what the OP was asking!:happyno:
I guess you missed my point. Is 120/240v considered low voltage of 12v considered low voltage? I depends upon the terminology that is common to those who work with the product 120v may be considered to be high voltage.
OP stated "What does it mean when the display in generator says low voltage, Is this the battery ."
Is it low voltage compared to what? Each person may have their own definition of what "low voltage" is depending upon their experience and the industry that they work in. If 120/240 is considered to be HV then one would assume that 12v is LV.
No the question is on the display pad of generator where you program system, the generator has stopped cycling and now the display reads low voltage, This doesn't mean LV 24 or 120 volts which is considered LV compared to 480 or 600 volts..... thats basic...
