Nope. Code only allows the mc to the first outlet without an AFCI breaker but then you must use an afci receptacle for the rest of the circuit. These receptacles are just about to make it to the market.
I still don't see any savings or other benefit of having the first receptacle AFCI protected. Unless it is an old breaker box that AFCI circuit breakers are not available.
I agree......an arc fault breaker is about $25.00. I don't know what the arc fault receptacle sells for but I'm sure they are at least $15.00 each and then you add the cost of the MC vs NM-B and it doesn't sound like it would be worth the trouble.
