I am tired of cheap magnetic bit holders.
Anyone has recommendation for good quality magnetic bit holder?
Thanks.
yeah i am referring to the 1/4" bit holder that goes in a screw gun.
i found these from WIHA and different variations on amazon and they look to be good quality.
http://www.amazon.com/gp/product/B0...pf_rd_t=101&pf_rd_p=1389517282&pf_rd_i=507846
Use an impact. I switched from running screws in with a drill to an impact 3-4 years ago, one of the best tool decisions I've made.
Same story when I switched from a sawzall to a metal circular saw, the sawzall rarely gets used anymore.
I've never owned and impact but I did use one that another guy had I believe that it was a panasonic. What type do you have?
I don't like those either. I opt for a bit holder that also uses a retaining ring on the inside of the bit holder that grabs onto that slot towrd the end of the actual bit. The bit is a bit harder to remove but it simply doesn't rely on the magnetics.
I believe that mine are made by irwin.
That looks like a good bet as the bit appears to be positively held in place as well as being operated by only one hand in order to change bits.
Looks like it releases by sliding back? Looks good. I have had the crazy issue of tek screws pulling the bit after a tough drilling. Like the screw gets magnetized & is stronger than the holder. Strange.
Thanks.
