Zeno
 - South Bay, CA
"225.22 Raceways on Exterior Surfaces of Buildings or
Other Structures.
Raceways on exteriors of buildings or
other structures shall be arranged to drain and shall be
raintight in wet locations." NEC 2008
I'm looking for a bit of clarification on how this code could possibly be executed.
For example, say I had a run of 2" IMC coming down through the eave that had to make a 90 degree horizontal turn to get over to the meter. Now, seems to me, this code is meant to keep possible water from making it's way inside the conduit all the way back to the meter (assuming it somehow got in through the weatherhead or some other means)...but how to drain? Would I manually drill some small holes at the 90 degree elbow (or LL/LR)? If so, the "drainage" holes would obviously have to be made before the cables were run, but then, would the holes damage the insulation?
Any help would be appreciated.
Zeno
			Other Structures.
Zeno
