There are requirements for clear working space about electrical equipment... and most center around the need to access while exposing energized parts.This question was brought to me by a co-worker(also a maintenance electrician), saying that he is almost sure there is a code requirement for clearance. If there is... i am unaware of it, and it is hidden very well.
The wireway IS equipment... just don't [usually] meet the criteria for needing clear working space.I follow what you are saying with exposed energized parts clearances, accessiblity, and equipment. But there will not be any equipment near, and it will be readily accessible.
The 2010 ADA Standards For Accessible Design DO have clearance requirements"Hello, this could possibly be an easy answer.....I'm unable to find if there is a code specific clearance
for the metal wireways and doorways. I.E. If said wireway has to be at minimum of 12" from the door frame.
Thank You."
