OK. It what way does charge controller differ from a voltage regulator?With a charge controller. The inverter also must sense the battery voltage and charge or discharge as appropriate.
Would the voltage regulator necessarily be more expensive?
I don't know the model number and they might not yet be UL listed for availability in the US, but I saw one in the SMA booth at SPI.Interesting. Which ones are those?
I don't know of a PV inverter which can supply AC current on demand at a fixed voltage without batteries*. Is it possible? I don't know the answer to that; I am not an inverter designer. But there is plenty of demand for something like that and it seems to me that if it were possible then someone would be doing it, even if it were a lot more expensive and a lot less efficient
* Actually that's not entirely true. There is a new line of SMA grid tied inverters that have an AC outlet that remains energized when the grid is down as long as there is insolation on the array, but it provides only a trickle of energy - a very small percentage of the output of the system when the grid is up.
Load it more and it outputs more up to the rating of the inverter. At least those I've dealt with do.I'm not sure where you're going with this. I think the issue is with how the inverter responds to conditions on the AC side of things.
On the solar fora in which I participate one of the most common questions posted is "why can't I use my PV array for power when the grid goes down?" People are constantly floating schemes whereby they would try to use a tiny battery to fool a grid tied inverter into thinking the grid is up. There is ample demand for a system which will provide constant voltage current on demand from a standalone PV system without batteries. To my knowledge there is only that SMA inverter I mentioned, and it only powers a single outlet at very low output. Load matching to power delivery curves is definitely one reason for batteries, but that's not the whole story, I'll wager. But I don't design inverters, I just use them in systems design. I can't say that it can't be done, only that it isn't being done, and it's not just because no one wants it.Maybe the absence of such systems is because there is no great demand for them. A battery can level out input fluctuations. And maybe the storage can allow the rating of the inverter stage to be reduced by converting the available input energy over a longer period.
Do you know what the usual inverter power circuit configuration is for t grid tied inverters?On the solar fora in which I participate one of the most common questions posted is "why can't I use my PV array for power when the grid goes down?" People are constantly floating schemes whereby they would try to use a tiny battery to fool a grid tied inverter into thinking the grid is up.
No, I don't. I deal with the guzintas and guzoutas, but they are black boxes to me.Do you know what the usual inverter power circuit configuration is for t grid tied inverters?
I think perhaps the inverters you have dealt with have fundamentally different designs. I'm not an engineer or inverter designer any more than ggunn (less actually). But my understanding is that solar inverters generally have a digitally controlled H-bridge IC.
This one isn't exactly 'usual' because it has two MPPT inputs. Ignore one of them and I think you have pretty much the "usual."
http://www.power-one.com/sites/powe...energy/datasheet/pvi-3.8_4.6-i-outd_us_en.pdf
Here's one that's "transformerless."
http://www.power-one.com/sites/powe...nergy/datasheet/pvi-3.0_3.6_4.2-outd_us_0.pdf
The DC/DC converter, that which I called a voltage regulator, is there to get from PV voltage to inverter input voltage and employs a switching device, the capacitor following it and an IGBT inverter stage.
Yes, but the point is that it's there. So it isn't an additional bit of hardware.Note that it's not just any voltage regulator. It's a DSP controlled maximum power point tracking device, meaning it's seeking an input voltage that delivers the maximum power from the solar array.
It is possible to build a solar panel without a MPPT circuit in which case no batteries are required. But the system would be very inefficient.Yes, but the point is that it's there. So it isn't an additional bit of hardware.
And, as far as I could tell, no batteries were shown.
I am not sure what this means. By "solar panel" most people are referring to a solar module, and solar modules do not contain MPPT circuitry. I don't think that whether or not an inverter has MPPT tracking circuitry has anything to do with whether or not it requires batteries to operate in the absence of an active grid tie.It is possible to build a solar panel without a MPPT circuit in which case no batteries are required. But the system would be very inefficient.
Sorry for confusion.
Take a 'plain' solar panel with no battery back up and no MPPT circuit in the inverter and no grid tie as well. Such a panel is still capable supplying power to a home. But maximum power to the house can not be assured due to absence of MPPT circuitry.
But if MPPT circuitry is added to it, maximum power is assured with one condition that load be present across the inverter terminals. The condition is always fulfilled by providing batteries.
With MPPT, power supplied is maximum irrespective of sufficient is load is there to absorb it or not. When sufficient load is not there, system voltage rises to account for maximum power. To prevent it, the inverter is provided with batteries to absorb excess powerI don't see why this would be true. The MPPT circuit works on the DC side (input) of the inverter; why would the AC section care if there is MPPT on the input or not? And a battery is a source, not a load;
It means that battery inverters are so designed and a standalone solar panel may supply power to a load even without any inverter battery.battery inverters never have MPPT. The MPPT in an offgrid PV system is in the charge controller, not the inverter.
This sounds like rude to me.this sounds like nonsense to me.
Sorry, you both seem to be wrong in that an MPPT circuit changes the switching duty cycle of the inverter so that the output power to the load is maximum by making the source resistance equal to the load resistance. But if the load can not accept all this power, the voltage would rise and to prevent this, the inverter is provided with battery to absorb this excess power also,Haji, ggunn is right. The presence of an MPPT component makes no difference to the subject being discussed here. An MPPT is just a DC-to-DC conversion that maximizes the efficiency of the PV circuit. The MPPT has essentially no effect on the output after it passes through a charge controller or inverter. It is the charge controller or inverter that will have to respond to any change in load or power supply.
