We are installing Hospital Grade MC cable on a job, can the redundant ground conductor that is a copper wire be pigtailed and terminated with the aluminum bonding conductor under the same green screw. or does the code require two green screws in the box? I am being told by an inspector that wire-nutting and pig-tailing the two is a problem due to the dissimilar materials
