We have a situation with two 50kva pole mounted transformers, each recieves a phase power lead and a ground from the local power grid, so assume the primary is 7.2KV. On the 480v secondary of each of the transformers, there are 3 terminals: One goes to the service entrance switch, the center one ties to ground (and connected to the other transformers center lug), and the third terminal ties to the third terminal of the second transformer and then goes to the service entrance switch. That makes 3 leads and a grounded guy wire going from the pole to the service entrance switch. The drawing shows a 3 phase 480v service entrance. Is that possible with this configuration of transformers and if so, how?
