A broader description of the install and problems you are dealing with would be helpful.I have older sealtight fittings that are not holding newly installed sealtight. Any ideas on how to make this work without having to disassemble everything to replace the fittings?
Non metallic or metallic?
I have never had any of the connectors I have installed come loose.
You are lucky. I have seen a lot of flex of various kinds come loose over the years. The connectors don't come out but the seal tight falls away from the connectors.
You can install grips on them that helps.
I think it is the weight/force being applied to the flex along with the vibration.
And stumble bum tech's steping on them. Usually it's a case of not being installed right in the first place. They get hand tightened only.
I have seen a lot of loose ones over the years. Very few appeared to have been stepped on. Perhaps an installation issue.
IME it is less likely with the all plastic version than with the stuff that has the metal under the plastic outer layer.
So hand tightening the connector will hold the sealtight in better than if you snug it up with a tool? That doesn't seem right.Usually it's a case of not being installed right in the first place. They get hand tightened only.
Oh, I see. That would make more sense.I think he meant that hand tightening was why they come apart.
There is no reason a properly installed sealtight fitting will fall apart.
By properly installed I mean the fitting is instaled correctly, tightened and the sealtight is supported as required.
You must see a lot of poor practices.
