Is it faster to suck the "mouse" thru a line of PVC or blow the "mouse" with a vaccumm?
Yes.
Lol. Which one is it or does it matter?
i use a "ghost" made from a baggie, tied to the string, works better than a foam mandril, wont stick, sucks through fast.
On large underground runs I prefer to install the poly line as I go. Then I replace it with a 1/4" or 3/8" poly rope when I get it all installed. We quite often install 1000' runs of 5" for the utilities and a run that long can be a booger to suck or blow a string through. I tie the line to a 3' piece of 1/4" rod with an eye bolt on each end, you can throw it through a 10' stick of 5" easily and it will bend enough to push through your 90's.
Sucking gives you a max PSI of 14.7. Compressed air can give you a lot more than that.
I have also found when blowing string in PVC stub ups it's easier to drill a hole just big enough for your string in the side of the pipe. That way you can get a good seal on your compressor hose. Drill it near the end of the pipe and the TA or bell end will cover it.
How do I feed the string? I cheat. I use "tampons." That is, I use store-bought gizmos that consist of a foam plug and a coil of very fine string; the whole thing goes in the pipe. I just secure the loose end at the start. The complete package looks like, you guessed it, a tampon. I think they were first developed for use with CO2-powered guns.
Anyway, this fine string is then used to pull back a proper twine, or string.
the last time i used them was in 1985, on a hotel.. we blew all the phone
home runs in about 30 minutes.. it was awesome. first blast from the compressor
is to clear the line, second is to blow the string... goes 100' in about a second and
a half.....
I have used this type of compressor before to blow lines. But I wonder if a small compressor has enought air flow (CFM) to do the job fast. What type of compressor are you referring to?
