Microwatt
 - North Dakota
This may be more of a mechanical question but you guys are smart so I figured you could answer it. Let's say you have a fairly large heating/cooling system that uses only water. Now let's say you make that water a 30% glycol/water solution. Would you expect the pumps to draw more current or less current with a mixed solution vs just water? The way I look at it the solution is heavier so it should create more head pressure on the pumps which would mean less volume and less volume would mean less work to be done, hence less current draw. Just like a fan. The less air you move the less work the fan has to do. Or, would increase in viscosity cause the pump to have to do more work with less volume?
