stevenbouf
Hello everyone My names Steve and I'm an electrician from RI. My problem is I have a building I'm wiring with four bath rooms and one common exhaust fan remotely mounted. Now how can I be able to control this fan from each bathroom by motion. Im not sure if these motion sensors can be linked to control a relay. Or maybe four single pole motion switches wired in parallel to a relay coil but wouldn't the activated switch back feed the other switches. Does that even matter. Also all the bath rooms will have motion switches to control there individual lights. Of coarse im trying to keep the cost down there has to be a way without some expensive control panel. Thank you.
