lightlytoasted6
- Portland, Oregon, USA
Hello,
My journeyman and I are currently installing a new motor control center for a customer, when we encountered a problem. We were contracted to install 1.5" RMC to run the conductors between the disconnect switch (on a mezzanine downstairs) and the unit. Unfortunately, no one bothered to check FLA for the machine being installed, and, where we were originally going to install 1/0 conductors, we now need to pull 2/0 conductors in. To add, the pipe is already installed, so we are looking for alternatives where the EGC is concerned, to avoid having to demo and reinstall larger pipe. According to 250.118, the conduit itself is acceptable as an equipment grounding conductor, but would this be kosher for feeders? I have yet to find anything to the contrary in the code. Could we simply attach a ground bushing and run a #6 jumper in each respective end? Thank you for your time.
