joeblurton
- Fargo ND
I was just amazed at the ground provided in a Sq D MCC. This is 250 amps 480 v. supplying a VFD. The screw holding the lug is an 8-32! The connection surface is painted, and a galvanized screw with copper lug are dis-similar. This is brand new switchgear. I know a ground fault will "spit" on this connection. Also the gear itself had many sharp edges and bending the 250 kcmil was impossible, as the auxiliary gutter was about 3" wide.
I ream conduit, scrape paint on grounds, with diligence, Why do manufactures get away with this shabby product?
