Aleman
- Southern Ca, USA
Does the NEC specify regarding power cords for machinery that plug into a receptacle? What brought this up is a compressor being put back into service. It draws about 15 amps at 208V 3P. The plug on the compressor was a 30 amp and the wire was 14-4 SO cable. So even though the 14 awg wire is ok for 15 amps, it can be plugged into a 30amp circuit. So, should the wire be sized according to the supply or the load? I would think if the load has over current protection it would be ok, otherwise the wire would need to be sized for the supply.
I looked and couldn't find an answer. But it is possible I am being blind. My wife tells me that all the time.
