I have a canopy array installed in a parking area (Canopy 1). The inverters and AC and DC disconnects are located at that point. Output of inverters combine in a subpanel(PV Panel 2{MLO}). I then have an approximately 1200 ft run back to another inverter pad where two inverter outputs plus the PV Panel 2 output combine in PV Panel 1 . The feeders from PV Panel 2 run underground for 800 ft then enter and pass thru the building then re-emerge to to terminate in PV panel 1 (MLO). From PV panel 1 to an AC disconnect, then the feeders re-enter the building to point of interconnection and are terminated on a line side tap. Question. Where feeders from PV panel 2 enter building and pass thru is an AC disconnect required as per 225.31? The original plan shows all feeders remaing outside the building, but due to field conditions utility power, gas and water mains in the way this is the resulting fix, the engineer does not specify a disconnect at this point, but I'm not convinced that I don't need one.This will obviously be a change order and I would like to do this prior to wires being pulled. Any help is greatly appreciated.
