mark32
- Currently in NJ
I'm replacing all the receptacles in an office and about 25% are in wiremold. The original installer did pull an egc but did not bond the box but did ground the receptacle. The first few I came across I went through the trouble of tapping and threading the existing hole in the backplate. (For some reason none of them are threaded?) I would then bond the box (Back plate) and jump to the receptacle. I eventually ran out of time and ground screws but I have to return anyway to finish. My question, due to the fact I'm using self grounding recptacles, could I just bond the back plate or would I have to, as I've already done, jump off to the receptacle as well. I wasn't planning on spending the extra time to disassemble the box and drill and tap these back plates so saving me at least one step would help.
![Metal Rwys as Ground Path - page 2[1].jpg Metal Rwys as Ground Path - page 2[1].jpg](https://forums.mikeholt.com/data/attachments/2/2213-ae5a9384e4e2e0c69c8b82a5208b94ed.jpg)
