Duncan8943
- Lexington
Does anyone know of any real online electrical wholesalers that are competitive? Our local wholesaler, Home Depot, and Lowes are typically much less expensive on #12 and #14 NM Cable.
I always see the big box being less for high volume items, like one gang nail on boxes, residential grade receptacles and switches, and NM cable in sizes 12 and 14, and maybe 10. Some loadcenters are priced pretty well, others are just competetive with supply houses. Most other items are either competitive with supply house or higher. Sometimes you will catch NM cable at just right time and it will be a great deal, but it is for short time just before they increase price when everyone else has already raised their price, same is true when there is a price decline.Around here copper is the same or cheaper at the big box stores. Some other stock is outrageous at the big guys, for example an 1-1/2 emt conn is $6.50, a 2-1/2 is around $7.50, but if you need a 2" connector, well thats gonna set you back $32.50hmy:. The couplings are the same way.:?
The Depot will price match though so if do your home work you wont get ripped off.
for switches, outlet boxes, receptacles, Home Depot is much cheaper. go buy a case of each. they are dirt cheap. usually they are about the same price on residential style panel boards as we can get from a supply house.
