Flashability
- Charleston, SC
I have an unusual situation here. Owner is putting a semi-permanent tent around an existing public swimming pool. In the event of a hurricane, plan is to remove side-wall and roof tent fabric and leave open aluminum structure to ride out the storm. Tent supplier is providing lights, exhaust fans and fabric inflation air compressors but will need power for them. My plan is to supply power into tent from a new NEMA 3R panel mounted outside the tent on the side of the existing CMU walled building. Original plan was to run branch circuits underground through a couple 6? sleeves through the concrete footing; however, workmanship in installing footing and sleeves rendered this option unusable. Plan B is to run power overhead into the tent through the sidewall. For this purpose it would be nice to utilize a cable tray; in fact, running a cable tray around the inside of the tent and dropping down with RMC at the loads would be a good way to distribute power throughout the tent. Reading through NEC Article 680, cable tray is not specifically prohibited, but it?s also not listed as allowable either. Article 680 does allow the use of armored cable which could be run in cable tray rather than tray-cable, but that seems rather expensive and it would be sure to raise aesthetic objections if it?s not run through conduit at the loads. Does anybody have any useful insight here? Does anybody have a better approach? Thanks!
