Aleman
- Southern Ca, USA
I have a pond with 3 pumps that feed 2 waterfalls and and stream. The wiring is a mess but that's a different story. I am looking over article 682 regarding bodies of water.
1st thing is the pumps are on SOW cords. The plugs were cut off and they are wired into a water tight box that is crammed in to some rocks that surround the pond. From there the installer ran SOW cord underground to another in ground water tight box and then PVC to the panel. That's another story also, I know it needs to be redone correctly with PVC or UF. In 682.14 it specifies that submersed equipment should be cord and plug connected. So, is this ok that the plugs were cut off and wired into the box?
These pumps are not on a GFI. 682.15 says that 15 and 20amp receptacles should be GFI protected. But the way these were installed, there are no receptacles. My opinion is that these need to be on GFI's.
Any opinions or suggestions welcomed.
