- Tennessee NEC:2017
- Semi-Retired Electrician
I know usually any kind of GFCI (breaker or receptacle) trips because of a fault in the equipment or wiring. However I have a situation that I can't figure out.
A hair dryer in a bathroom often trips the GFCI breaker. What's different about this is it only trips when plugging or unplugging the hair dryer. It never trips while the dryer is being used. I checked the receptacle and did find some loose (not extremely loose) connections. I replaced the receptacle and made sure all the connections were tight.
It still trips the breaker occasionally, not everytime. Again it's only when plugging in or unplugging the hair dryer. It's not tripping on overload because of the obvious.
Also, the switch on the hairdryer is never on when this happens.
Any thoughts on this?
