powerplay
- In front of a computer.
On a private farm there is an 75KVA Pole mount Power Authority transformer that is being replaced with an private 50KVA Pole mount Transformer with 120/240volt secondary lines to power a home with a 100amp panel, and a 200amp Lighting panel for a Commercial Greenhouse.
... The question before deciding where to add another meter and panel for the Common Well Pump shed as well as another "House" panel for a warehouse is how much can be drawn off the private 50KVA Pole mount transformer? The customer is skeptical because they have an existing 75KVA transformer that was permitted through the Power Authority to feed a 200amp 120/240volt Commercial Panel and the 100amp Home Panel, and now that they are returning the 75KVA pole mount Transformer to the Power Authority and putting in their own private pole Transformer, they were told from a salesman it would handle far more load than the existing 300amps. I was told when the Power Authority sizes the transformer, they allow the pole mount Transformer to be loaded over 150%, but when the same Transformer is on private property the derating calculation changes and they reduce the amount it can be rated for...... Seems to me 50000VA/240volts=208amps ... What is the allowable load for a private 50KVA Pole mount transformer with 120/240volt Secondary output??
Thank again in advance for your help!
