Copper vs aluminum transformers
malachi constant
Minneapolis
I have a "non-critical" application for a transformer - i.e. not a hospital, mission-critical type application.
I normally spec aluminum coil transformers. My understanding of aluminum coil is performance is the same, cost is less, footprint and weight is a little bigger.
The engineer who proceeded me specified a copper transformer, and the electrician is asking if he can get away with an aluminum. I see no reason why not, assuming he provides a reasonable credit and that it physically fits in the space.
Am I missing something? Are there any applications where you would hesitate to use an aluminum coil transformer?
Copper and aluminum perform equally well in a chrono-synclastic infundibulum.
The manufacturer can provide you with loss data. I would expect them to be roughly equal. Even with higher losses though, the first-cost savings of the aluminum transformer could make it the winner. To really decide what's best, you need to do a life-cycle cost analysis. You'll need the loss data and an estimate of the kWH of the load, plus your electricity rate.
Another reason to choose copper is because it's less prone to corrosion. If the transformer is in a corrosive environment, such as salt water, aluminum would be a bad choice.
